Transfering mp3 to music server
Old Oct 9, 2007 | 02:32 PM
  #51
Ceram's Avatar
Default RE: Transfering mp3 to music server
Are there some progress to report in this matter?
Just curious
Old Oct 9, 2007 | 03:11 PM
  #52
BacDoc's Avatar
A bunch of worthless IT guys around here!
[8D]
Old Oct 22, 2007 | 03:39 PM
  #53
Ceram's Avatar
Can someone out there tell me the size in mm for the MMCS unit?
Old Oct 22, 2007 | 06:35 PM
  #54
brian360's Avatar
ORIGINAL: Ceram
Just curious
Hey all -- I might have some huge findings in this... so a little teaser for now:
Over the weekend I sniffed the data bus from the MMCS to the HDD. I have reason to believe that unlock password on the hard drives is all the same for every unit -- so my work could benefit everybody. Now I gotta do some testing tonight trying to actually unlock the drive on my PC and will definately post my detailed findings in the upcoming days.
Old Oct 22, 2007 | 11:35 PM
  #55
GPSeek's Avatar
ORIGINAL: brian360
Congrat! [sm=bounceybounce.gif]
Keep us posted. You probablly need to start with a new thread and let the admin make it sticky.
Old Oct 23, 2007 | 01:16 PM
  #56
brian360's Avatar
ORIGINAL: GPSeek
Thanks! Now the burning question -- do I start a new thread in the Outlander section or the Lancer section? I'm sure the info applies to both -- and I drive the 08 lancer.
I can say that it appears the MMCS encodes music to "RIFF (little-endian) data, WAVE audio, stereo 44100 Hz" format as "*.sc" files in a directory tree. I have no idea how the database stores the track names and what not, so there's still more hurdles to transferring our own mp3s to it. Also all the boot-up animation and screen backgrounds (including the rear-view camera guides) are either bitmaps or (animated) GIF images -- i'm sure they'll be easy to change!
Old Oct 23, 2007 | 02:41 PM
  #57
GPSeek's Avatar
ORIGINAL: brian360
ORIGINAL: GPSeek
I would say here for sure. You can do a quick check on both forums and find out this sub-forum is much more active than Lancer's
The work you did definitely deserves a seperate sticky thread.
You suprised me by saying they use wave format that is less efficient in terms of storage.
Some quick questions:
Is the MMCS running Linux as I guessed before?
Is there just one partition?
Old Oct 23, 2007 | 02:52 PM
  #58
brian360's Avatar
Unfortunately, all signs point to the MMCS running a Windows/DOS-based OS. I was really hoping for Linux, too I don't see any executable files, so I'm sure the OS is in Flash memory, and it only uses the HDD for data storage.
There are 6 partitions (3 primary partitions + a logical partition with 3 more partitions):
Disk /dev/hda: 30.0 GB, 30005821440 bytes
255 heads, 63 sectors/track, 3648 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hda1 1 2611 20972826 c W95 FAT32 (LBA)
/dev/hda2 2612 2627 128520 c W95 FAT32 (LBA)
/dev/hda3 2628 2692 522112+ c W95 FAT32 (LBA)
/dev/hda4 2693 3647 7671037+ f W95 Ext'd (LBA)
/dev/hda5 2693 2823 1052226 b W95 FAT32
/dev/hda6 2824 2954 1052226 b W95 FAT32
/dev/hda7 2955 3647 5566491 b W95 FAT32
The partitions as I can determine are:
1: 20GB total, 9.9GB used, 11GB free -- Has all the map data
2: 125MB total, 0 used -- Empty
3: 509MB total, 24MB used, 485MB free -- has a single file "loading.kwi"
4: (logical partition for the next three partitions)
5: 1.1GB total, 9.0MB used, 1019MB free -- has all the background images, bootup animations, screen files, etc.
6: 1.1GB total, 346MB used, 682MB free -- CDDB Gracenote database
7: 5.4GB total, 1.5GB used, 4.0GB free (in my case) -- Music Server files
The songs are compressed -- each file seems to be about 3-4 MB in my case -- it just doesn't appear to be MP3 format. I'm at work rightnow, so I haven't had a chance to play them in VLC or something, but i'll do a "formal" writeup thread this evening and some more experimentations.
Old Oct 23, 2007 | 03:34 PM
  #59
GPSeek's Avatar
No sign of unix file structures in hda1 at all?[8D]That's a big surprise to me.
Are you saying it's running Windows 2003/Mobile/CE?
They hide all the op sys and device drivers in the ROM?
Nothing is left on the drive?
Old Oct 23, 2007 | 05:17 PM
  #60
rcpax's Avatar
ORIGINAL: brian360
It is Proprietary MP3from what the manual says. So that could translate to MP3+DRM probably? And manual says you won't be able to play in the PC or any other player except MMCS. Just a little FYI.
Dinan540iS6MT
Aug 16, 2011 10:59 PM
Roq
May 6, 2008 02:42 PM
ash
Sep 2, 2007 05:32 AM
Yachtie
May 31, 2007 05:49 PM
cerberus9
Apr 12, 2007 05:02 PM
