Transmission fluid for 07 XLS ..
Old Jun 28, 2009 | 06:37 PM
cybergoogle's Avatar
Default Transmission fluid for 07 XLS ..
Have anyone replace / change the transmission fluid?
Is Save to use non-mitsubishi fluid?
Old Jun 29, 2009 | 05:54 PM
Manybrews's Avatar
it is NOT safe to use non mitsu fluid.
why on earth are people so adverse to using the correct fluid on these boards? go buy the correct stuff.
Old Jun 29, 2009 | 06:06 PM
QwikEVO's Avatar
I just got the tranny fluid changed and used Diaqueen or whatever Mitsu calls it. I didn't have much information from anyone on here about whether or not you could use something else or I would have.
I use BG Syncroshift in my Evo. F spending that kinda money when BG has a comparable or better product for cheaper.
Old Jun 29, 2009 | 06:12 PM
BrokeDad's Avatar
(deleted)
Old Jul 1, 2009 | 12:00 AM
Manybrews's Avatar
dont buy the marketing.
For the most part, gear lube is gear lube. There are some synthetics out there, but if the car doesnt call for them you're wasting money. The MR evo is the only one that does.
Auto trans fluid is different due to the varying additives and co-efficient of friction.
A manual trans will usually shift fine no matter what you put in it.. motor oil, ATF, GL-3, 4, or 5.. An auto trans, not so much.
Old Jul 2, 2009 | 01:58 PM
bnilguy's Avatar
I couldn't find any info about the DiaQueen standard..so I'd play it safe with the Mitsubishi product
newoutlanderfan
May 27, 2013 10:47 AM
Trick
Nov 21, 2008 04:56 AM
marollocd
Nov 13, 2008 04:59 AM
jcasaccio
Jun 6, 2006 06:14 PM
glennsafrit
Oct 25, 2004 12:29 PM
