Trunk release outlander 2003
Old Jun 25, 2013 | 04:26 AM
mitsucats's Avatar
Default Trunk release outlander 2003
Hallo
i am living in German and have Mitsubishi Outlander 2.0 4WD from 2003 and i have hard to find the answer for my question and therefore i have use google and end up here and hope to get help for my question.
I have a 2 buttom Remote for my Car "Remote"
I would like to buy this
Trunk release
But how do i make it over my original Remote when i only have 2 buttom. is it possbile to make so i hold open or lock for 2-5 seconds then it activate the trunk release ?
If this is possbile what for color of kabel in the car do i need to find ?
if not it the only possbile then to buy so a set here ?
Funkfernbedienung mit Klappschlüssel - Kofferraum - Blinkersteuerung
Kind Regards
Henrik
Old Jun 25, 2013 | 02:17 PM
Akzle's Avatar
what do the two buttons on your remote do?
What frequency does it use? (kHz, kilocycles)
does it use a rolling code?
All things are possible, if you have enough time and money.
You will be wanting to buy a RF receiver that suits the remote's frequency, and an electrical relay
Old Jun 25, 2013 | 02:20 PM
Akzle's Avatar
Old Jun 25, 2013 | 03:44 PM
mitsucats's Avatar
Hallo thank you very much for you fast help.
i dont know all answer of you question. and i try to find out but Mitsubishi is not so help full here in deutschland.
As show on the picture lock and unlock nothing else.
I have no idea, where do i find that out. it is original
Remote system from mitsubishi when i buy the car
Again where do i find the info?
4-Channel Wireless Remote Control Relay with 2 Key Fobs- Jaycar Electronics.
Would that say i can programering my remote into this relay and use the remote that follow with and not my original or how goes it. i know alot but few thins i just need to have a little help and info then i can come to next step.
Old Jun 25, 2013 | 05:08 PM
Akzle's Avatar
with that jaycar unit, you would have to detach the central locking from your car, and wire into the new unit.
Then you will have your lock, trunk release, and two spare buttons. You could wire an alarm or remote start.
If you open your remote, you may find the mHz printed on the inside cover. If not, there will be a crystal on the PCB that should have the frequency printed on it.
You will not be able to use that remote, unless you want to open the trunk every time you unlock the doors!
Old Jun 26, 2013 | 01:18 AM
mitsucats's Avatar
Hello
I have just open the remote and there stand something with 525m can that be the mHZ
Old Jun 26, 2013 | 02:41 AM
Akzle's Avatar
possible, i dont know what frequency allocations in germania.
I would expect 433 or 27
http://www.wsplc.com/acatalog/mzx.jpg
You wont be able to use that remote though.
Old Jun 26, 2013 | 03:09 AM
mitsucats's Avatar
It was write on the PCB
G8D-525M-A
But i think the best way is to buy this set there i get all in one..
Funkfernbedienung mit Klappschlüssel Komf.- Kofferraum - Blinkersteuerung | eBay
Old Jun 26, 2013 | 03:36 AM
Akzle's Avatar
that will be a production number.
I dont sprich ze deutsch, but that looks like it will work,
good luck!
Old Jun 26, 2013 | 03:54 AM
mitsucats's Avatar
Hello
No deutsch is also very hard hehe. i speak englisch or deutsch or danisch.
I have try to look at ebay.com and i dont find manye firms that send to deutschland. you can buy much better and cooler remote in ebay.com
RMede89202
4th Generation
Dec 5, 2012 01:27 PM
leonardh2@hotmail.com
May 25, 2009 09:33 AM
elmiserable
Jan 20, 2009 08:18 PM
elmiserable
Jan 20, 2009 08:13 PM
drobjr
Oct 29, 2005 10:18 PM
