Turn Signals
Old Jun 25, 2008 | 05:02 PM
Mickey 4x4's Avatar
Default Turn Signals
Please help an old(er) Outie owner. I have had my UK elegance model since Nov 2007 and love it.Howevermy wife and I have one small issue, we keep leaving our turn signals on !We are both finding ourselves cruising down the motorway/highway with our turn signal flashing away from a turn made miles ago!! The self cancelling function is working ok but there is bearly no audible warning from the indicator at all. PLEASE guys .... don't give us the "learn to drive" line. We have over 60 years drivng experience between us ! It really is a feature of the vehicle that we just don't get on with.
I want some advice so that I can wire in a small buzzer that will operate as the indicators flash to ensure we switch off after use ( maybe old age is looming faster than I thought ..... safety first ?!?!?)
I amworried about tapping into the circuits because I think it all controlled by computer in the Outie. Can you give me some ideas please, how/where can I wire a buzzer in. Could you tap into something in the steering column?
Very many thanks ..... Mickey
Old Jun 25, 2008 | 05:19 PM
Default RE: Turn Signals
The 60 years experiance just about says it Just playing.
As far as making something to make a sound.... you could remove the gauge cluster and wire in a small buzzer onto the same circuit that the bulb operates on.
Old Jun 25, 2008 | 08:48 PM
JohnMadison's Avatar
I just find it odd that the wife isn't screaming & telling you to turn it off.
Old Jun 30, 2008 | 02:59 PM
puddy's Avatar
Hi Micky 4x4 i need your help.
if you have the none satnav system and cannot read the radio display in bright sunshinebecause its too dimto read the clock or seewhat station can you onplease e-mail. m@puddy.co.uk
I need your reg so I can ring Nadine Haywood at Mitsubishi HQ in the UK
Kind regards
Michael
Old Jul 1, 2008 | 01:46 AM
HandyPal's Avatar
Hi Micky,
Other option would be to find a relay that controls the indicator bulbs on the dash and hardwire your buzzer. You also need to make sure buzzer's input impedance is high enough to not overload and/or interfere with existing circuits. Ideally, a separate power to the buzzer and sensing inputs for the right and left turn signals would look like a proper setup. I can dig up some diagrams to be more specific, but you willneed to make some measurements/tests and installation. First obtain a good buzzer.
Good luck.
Old Jul 1, 2008 | 03:06 PM
Sergy's Avatar
Oneguy made very simply: he bought 2 cheap piezo buzzers (they have a high impedance) and soldered each on bulb contacts under dash.
Two bulbs (left and right turn signals)- four contacts - two buzzers.
30 minutes at all.
Old Jul 10, 2008 | 10:09 PM
n0c7's Avatar
Maybe a classic style flasher that has a noticable clicking noise.
Mac_attack769
Sep 23, 2006 07:52 PM
udg21
May 2, 2006 04:58 PM
fred
Oct 16, 2005 05:17 PM
Britvalencia01
Oct 6, 2005 11:57 PM
odecca25
Jul 13, 2005 01:58 PM
