Underboost Issue
Old Jan 9, 2021 | 08:32 AM
Rizla93's Avatar
Default Underboost Issue
Hi, I have a 2013 mk2 outlander gx4. A couple of days ago I had the ASC service light come up on a short drive and the car seemed to go into limp mode (loss of power). The following day I started the car up and the ASC light had gone off but the yellow check engine light was on and has stayed on since. The 2 codes that came up were p0299 and p0106. The car still has no power and makes a kind of whirring noise when accelerating fast. I have been told that this may be a split intercooler pipe as when accelerating the pipes are soft and squeezable. I can not, however, find any splits in the pipes. Any help appreciated? Thanks in advance.
Old Jan 9, 2021 | 04:09 PM
DibbyDibbyDJ's Avatar
The large pipe down the front of the engine. It goes from the throttle body to the intercooler. That is the pipe that could have a split.
Those codes maybe caused by a build up of carbon in your inlet manifold. Especially around the small pipe that goes to a port for the boost pressure sensor. This carbon can be caused by a split pipe, or maybe caused by a faulty EGR valve that is sticking.
Old Jan 12, 2021 | 08:05 AM
Rizla93's Avatar
Thanks for your reply dibby. I managed to find a loose connection on the pipe that connects directly to the turbo at the back of the engine which I think was causing the boost leak. Do you have a picture of where the map sensor is located please? As I think it needs changing
whteclipse
Jul 2, 2005 10:02 AM
reboot_dc
Aug 24, 2004 08:59 PM
boosty
Aug 12, 2004 02:41 AM
eclipsegsxgrl18
Jun 22, 2004 12:45 PM
EclipseDriver
Feb 27, 2004 01:55 PM
