Vibration under acceleration 2007 Outlander
Old May 12, 2017 | 08:50 AM
SJSnelling's Avatar
Default Vibration under acceleration 2007 Outlander
2007 Outlander w/216,000 miles. Recently purchased. Under acceleration, vibration is felt from the front. If I turn left (accelerating) the vibration stops. Right turning the vibration increases slightly from that felt going straight. All CV boots are clean/dry. Right CV axle displays only minor in-and-out movement (accompanied by a clunking) and torsion (twisting) the same. Left half shaft is tight w/no clunking. I suspect I have an inner right CV joint issue, yet not certain. Only other issue found is the left strut has developed a leak (right appears to be new). Any other areas I should be checking prior to changing the right half shaft?
Thanks in advance
Old May 15, 2017 | 09:17 AM
SJSnelling's Avatar
Suspecting the issue is an inner axle joint, I spent more time inspecting both left and right front half-shafts. I can feel a metal-on-metal feeling coming from the left inner while engaged/rotating, although no discernible play . I've ordered a replacement. I'll know soon enough if I accurately diagnosed the cause of the vibration...
Old May 21, 2017 | 07:16 PM
deadguy's Avatar
Hi SJSnelling, how is it going?
I have the outlander 2007 and hope that it won't have same issue as yours.
golo
Mar 25, 2025 02:14 PM
Maui4me
May 7, 2017 02:19 PM
Ayad Zaiya
Feb 27, 2017 10:17 AM
newoutlanderfan
Dec 13, 2011 09:01 AM
jerusry
Dec 2, 2006 06:45 PM
