Weird Series of Clicks when Key put into "On" position
Old Mar 29, 2011 | 10:51 AM
firstorbit84's Avatar
Default Weird Series of Clicks when Key put into "On" position
I've recently noticed that when I turn the fastkey **** to the second position, "On", just before turning it to crank the engine, I hear a series of fast clicks coming from the driver's side of the engine bay. They sound like a bunch of relays turning on and off very quickly for about 1-2 seconds. Everything seems to be working properly. Is this sound normal, or should I take it to the dealer??
Old Mar 29, 2011 | 12:57 PM
mirageman2's Avatar
I believe it's normal, I get it in my 04 2.4liter as well, sounds like it is supposed to do that
Old Mar 29, 2011 | 02:28 PM
Thanks for the response. You don't know what it is for sure though? I may check with the dealer anyway.
Old Mar 29, 2011 | 04:43 PM
bender031177's Avatar
I have worked at a Mitsu dealer since '04 and every Mitsu does it. I was told it is the fuel system pressurizing. I don't know if thats true but it sounds good. It is normal and nothing to worry about.
Old Mar 29, 2011 | 05:43 PM
Bizarre, but Ok I believe you.
Old Mar 29, 2011 | 08:09 PM
kalayaan's Avatar
normal on most cars. it's the fuel pump priming the fuel system.
Old Mar 30, 2011 | 10:25 AM
I don't know about that. I've owned and driven quite a few cars and I've never heard anything like this noise. Maybe its just normal on most Mitsubishis.
Old Mar 30, 2011 | 11:12 AM
Tech_735's Avatar
You r talking about a "SelfSafe" check. It is the "ABS" system clicking... don't waist your time going to the dealer. :P
Old Mar 31, 2011 | 02:11 PM
thanks, this honestly seems like a more reasonable explanation.
Old Apr 2, 2011 | 06:24 PM
mahicks3322's Avatar
if it goes something like: CLICK CLICK CLICK CLICK CLICK at about a quarter to half second interval, it is normal. You will hear the fuel prime relay and everything else you hear I think I was told is related to the ABS system..
jsevinsk
Aug 14, 2022 10:36 AM
DarkPoet
Aug 23, 2014 05:09 PM
tonyblu
May 21, 2011 05:47 PM
treasguy
Jan 28, 2010 07:15 PM
