95 rs turbo problems
Old May 27, 2010 | 02:51 PM
import1978's Avatar
Still no boost after i took off the WG vac. I think it's the BOV now if the BOV has a seal in it or something that blew, and it's the only thing left between my turbo and intake. Cause the push of air sound also sounded like when my buddy blew a seal off his air compresser.
I took the BOV off and I could blow air through it just with my mouth. Air is coming out right before the air release spot. Thats the only spot I can't take off cause I don't have a small enough wrench till tomm, but hopefully it,s just a seal. But does that sound like air is being pushed out from the BOV at all times?
Old May 28, 2010 | 10:48 PM
import1978's Avatar
K weirdest thing just happen. I took the car down the road to a friends and out of the blue the boost kicked in perfect. What I was doing was playing with the gas pedal and thats when it kicked in.
But now before I made it home I lost boost again. Something sticking?
Old May 29, 2010 | 09:02 AM
i still think your wastegate could be stuck open
Old May 29, 2010 | 10:28 AM
import1978's Avatar
Well, I got boost now so far(knock on wood). What I think it was, is the vac source on top of my WG was almost wide open. There is a disk in there that blocks that source when not used. Believe it's used for a turbo timer. So I blocked the hole and took it down the road and boosted just fine. Going to buy a new WG to be safe it doesn't happen again.
Thanx for taking the time to help
jp2000
Jan 1, 2012 05:21 PM
p4c0
Feb 22, 2007 06:36 PM
5Tizzle
Oct 13, 2006 06:41 PM
gargola1227
May 21, 2005 03:16 AM
gargola1227
May 3, 2005 03:10 PM
