Boost cutting out - Need help!
Old Sep 17, 2006 | 10:04 AM
sherif_e1's Avatar
Default Boost cutting out - Need help!
Hi guys
I am running an Evo 6 at 1.1 Bar and am experiencing hunching when I start passing 5000 rpm... This is happening mainly from 3rd gear onwards for some reason and the turbo starts cutting out and losing pressure all the time. I thought it was a leaky boost gauge which I replaced with a new Greddy but still no change.
My Boost Controller has also stopped working and switching between low/high boost or switching it off completely has absolutely no bearing. I checked the HKS filter for dirt but its clean and I cannot find a solution.
I just had some HKS plugs put in but I am not sure if this is the problem. Could the plugs have made such a dramatic impact?? I some how doubt it...
Any suggestions on how to fix this or what else could be the root of the problem? (I was planning to stick a fuel regulator, modified fuel rail and a slightly modified Evo 7 Turbo this weekend, but its pointless to carry out the work until I find a solution...)
Any recommendations here would be greatly appreciated!
Old Sep 17, 2006 | 01:06 PM
Default RE: Boost cutting out - Need help!
sounds like a boost leak. How good is the BOV you have on it. And also check the IC piping and intake to see if there is a leak anywhere. Or it also could be the wastgate
Old Sep 18, 2006 | 09:53 AM
sherif_e1's Avatar
Thanks for that. I will run the test tonight and check the pipes... BOV is brand new - Tornado (I think its Australian...)
Old Sep 24, 2006 | 03:53 AM
importorigins's Avatar
Does sound like a vacuum leak but check your plugs and wires just to be sure. Also maybe the injectors are dirty. Just a thought
Old Sep 24, 2006 | 09:06 AM
What turbo are you running? It is normal for the T25 turbo to decreace by upto 10psi on the high end
Old Sep 25, 2006 | 01:04 AM
did you happen to read his post..he has an evo not an eclipse
Old Oct 8, 2006 | 04:42 PM
SpyderG-st's Avatar
hey bro. i would have to say its ur belts. whens the last time u changed them? cuz my turbo was doin the same **** until i got new belts now it runs like a charm
horms12
May 10, 2006 07:40 PM
brandoN^gsT
Feb 3, 2006 01:02 AM
Richie
Nov 5, 2005 05:35 PM
hoona
Jul 16, 2005 05:06 AM
gstowner
Oct 11, 2004 03:17 PM
