HELP ME PLEASE
Old Aug 10, 2006 | 04:04 PM
Default RE: HELP ME PLEASE
post a pic
Old Aug 10, 2006 | 05:13 PM
come on people its a 1g NA. There are only two possible solutions to the engine that is in there. One is the 1.8 SOHC or the 2.0 DOHC. In which both cases i believe the motor mounts are exactly the same. You shouldnt have any problem getting the laser motor in there. Yes take the ECU from the laser, and it should be located underneath glove box.
Old Aug 10, 2006 | 09:29 PM
slow420a's Avatar
ORIGINAL: TheEngineer
Everyone should buy this man a beer!
Old Aug 10, 2006 | 09:34 PM
a beer for the mighty engineer!
Old Aug 11, 2006 | 01:27 PM
to bad i dont drink beer.
Old Aug 11, 2006 | 07:12 PM
import~newbee's Avatar
Do i need to swap anything eles out, Like wireing harness, fule pump?
Old Aug 12, 2006 | 12:53 PM
slow420a's Avatar
yes fuel pump would be a plus, so would injectors, fuel rail, fpr, wiring harness, all of the sensors(INCLUDING YOUR MAF), you will also need to swap the spedo/tach setup. Which may not be possible due to a hardwear change. Dsm went from a cable driven equipment to electronical but I dont remember exaclty when, either the 7 bolt switch or 2g switch.
LeoGS
Nov 6, 2020 06:12 AM
enzo_hashmat2006
Oct 10, 2017 05:46 PM
westentertainer
Nov 8, 2014 12:47 PM
lgibson
Mar 12, 2009 07:04 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
