starter
Old Jul 31, 2007 | 04:33 PM
spyder4g63t's Avatar
Default starter
searched and cant find location of starter..its not n the virtual engine bay ..havent been under the car but would like to see pics if possible
Old Jul 31, 2007 | 05:04 PM
TheAdvocate's Avatar
Default RE: starter
The reason you dont see it on there is because its behind and underneath.. If you jack your car up and look on the passenger side, you can see it on the back of the motor.. (Stupid place in my mind) You can also reach it with your hand from the top if you reach down the back passenger side.. You wont be able to work on it from there though..
Old Jul 31, 2007 | 10:40 PM
98gstspy's Avatar
Default RE: starter
i just replaced mine it was a pain in the ***. once it is out it is easy to put in. i had to pull out my battery and everything under neath. the you sould be able to get it after you remove the bolts pull it out from the bottom.
Old Aug 1, 2007 | 11:44 AM
Default RE: starter
thanks fellas im gonna go try that hammer thing now.hahah
Old Aug 3, 2007 | 04:58 PM
Default RE: starter
changed the starter still wont start what else could it be
Old Aug 5, 2007 | 12:46 PM
98gstspy's Avatar
Default RE: starter
did you check all of your spark plugs and wires?
Old Aug 5, 2007 | 05:50 PM
Default RE: starter
just changed to ngk..maybe ignition but how can i be sure..loose wire?>
stealth1
Jul 28, 2005 12:32 AM
Smejk
Feb 11, 2005 07:34 PM
cptkid570
Dec 23, 2004 03:47 AM
Flipz
Dec 12, 2004 04:51 PM
cptkid570
Nov 29, 2004 10:49 AM
