which turbo should i get
Old Dec 12, 2006 | 10:01 AM
Default RE: which turbo should i get
id go evo III 16g also. But you really are gonna need a whole lot more than that. Id plan on another 1-2k to get the whole setup running properly. Just make sure you do the reasearch and get all the right stuff for what your looking to get out of it.
Old Dec 13, 2006 | 01:43 PM
spyder4g63t's Avatar
now when u say 1k-2k that includes parts and tuning correct...hopefully! another question right now im havin fuel cut...with my stock setup i shold just get a fuel filter and pump to fix it right leave the injectors etc for the bigger turbo
Old Dec 13, 2006 | 02:23 PM
yes SAFC, injectors, fuel pump, guages, intercooler, ect.
Sure getting the fuel pump and new filter should eliminate it for now. But there is no guarentee. What boost are you running now, and what are the mods?
Old Dec 13, 2006 | 03:34 PM
my current mods are in my signature and my boost is stock..everything else is stock i havent raised the boost im also runnig soft pipes<i know it sucks my budget is tight tho..
Old Dec 13, 2006 | 07:31 PM
TheAdvocate's Avatar
you shouldnt be cutting out running stock boost... My buddies GSX didnt cut out until about 19-20 psi with stock injectors and pump..
Old Dec 14, 2006 | 10:04 PM
slow420a's Avatar
ORIGINAL: TheAdvocate
x2 that dosent sound right. I would repalce the filter and the pump becuase they need to be done anyway. But it dosent sound like those would be causing fule cut unless their really worn.
Old Dec 15, 2006 | 03:59 PM
ok so lets make sure i am getting "fuel cut"...when pushing it and hitting high rpms and i guess higher boost..all of a sudden it feels like i hit a brick wall and a loud *** pop sound happens..soooo...
Old Dec 18, 2006 | 12:13 PM
yup thats fuel cut...so is your question what causes it, or how to fix it?
Old Dec 20, 2006 | 05:42 PM
both ... they said its not likely for me to get fuel cut cause i am runnig stock boost...so yea i wanna know what causes it and how exactly to fix??and why am i getting at stock boost
xcronikx
Feb 8, 2007 11:50 PM
eclipsegsx
Aug 1, 2005 06:04 PM
97gstspyder
Jul 13, 2005 12:24 AM
darkman0127
Sep 25, 2004 06:35 PM
DeJa_Voo
Aug 11, 2003 01:11 AM
