whats wrong with my car??
Old Sep 18, 2008 | 04:27 PM
tim99gsx's Avatar
Default RE: whats wrong with my car??
im workin on getting the pics of the mods uploaded been way to busy working but seems like im definitely running rich since black smoke coming from the exhaust at times and also a random backfire once in awhile not to often. i have also noticed on the engine where there are the spark plug wires in that set in tray area there is oil in there? any ideas whats causing this?
Old Sep 21, 2008 | 07:40 PM
darknigh7th's Avatar
leaky valve cover gasket maybe, mine is leaking and it's sprayed oil all over the engine bay, some oil got into a spark plug and it wouldn't enter boost, everytime it got past the vacuum it would stutter like a ****, cleaned it up, replaced wires and plugs, ran fine. so definately clean it up, check your gasket.
Old Sep 22, 2008 | 05:11 AM
silvercoupe97's Avatar
A valve cover with a pool of oil sitting where the plugs/wires or on top of the valve cover itself could mean that you have a leaking oil cap. Oil in the plug area means that the plug seals need to be changed.
Backfire is normal for a car without a cat and with a high flow muffler or straight pipe. The cat usually catches those and the muffler usually, well, it muffles it.
Google "boost leak test" and "boost leak tester" or search it in here. I posted a link to a post of mine from another board showing a whole strew of boost leak testers some time ago.
Old Sep 22, 2008 | 05:32 AM
Well, since the board is allowing me to post in my regular manner again I was able to create my boost leak tester post from another board. It's in the Eclipse FAQ section, so, here it is.
https://mitsubishiforum.com/m_236302.../tm.htm#236302
maxpayne
Dec 10, 2009 03:55 PM
1GenNA
1st Generation
Jun 21, 2008 07:21 AM
KillerEclipse
Dec 27, 2005 06:51 AM
bjoelson_gsx
Aug 21, 2005 08:59 PM
