wild, out there A/C question
Old Jul 11, 2006 | 06:55 PM
mysterio2099's Avatar
Default wild, out there A/C question
Is it at all possible.. to route part of the A/C in a car (mainly a 2G eclipse) .. to blow INSIDE the engine bay? I know, it's crazy.. 100% ghetto rigged .. but, is it possible?
Old Jul 11, 2006 | 07:48 PM
slow420a's Avatar
Default RE: wild, out there A/C question
yes, but why, it will only be a waste of cold air.
Old Jul 11, 2006 | 08:20 PM
My tranmission slips when it gets hot.. but its fine when its cold.. I was thinking if I kept it cool (if that would even keep it cool) that I wouldn't have to dish out tons of bank to get my transmission fixed. lol. I'm a cheap bastard.
Old Jul 11, 2006 | 08:55 PM
slow420a's Avatar
just change the fluid, that should help. To be honest, to do that re routing would take alot of time and effort... and I dont think it would work all that well. If you want to lower the temp of the tranny, get a tranny cooler for a neon or something and I am sure that you could adapt the hoses to make it work... that or you could get a oil cooler off a old gm or ford truck, flush it and pipe it in, but thats ghetto as hell.
Old Jul 11, 2006 | 10:25 PM
I've already changed the fluid and filter... didn't do ****. I've seen these transmission cooler things online and stuff, but I never knew if they worked or how hard it would be to install them. How much do you know about it all?
Old Jul 12, 2006 | 01:15 AM
slow420a's Avatar
Well, it basically works like a radiator. The fluid cycles through it and get cool. They should come with specific directions but basically it will just have you tap an ingoing line into the tranny that carrys fluid and run the cooler through that.
Old Jul 12, 2006 | 01:23 AM
Know where I can go one? .. and.. if it really helps?
Old Jul 12, 2006 | 10:59 AM
slow420a's Avatar
Yes the really do help, no i dont know, I am too lazy to look at this point in time.
Old Jul 12, 2006 | 11:06 AM
I looked around a little bit, but I couldn't find anything that was made for a 2g eclipse. So.. me dunno. [&:]
Old Jul 12, 2006 | 11:08 AM
slow420a's Avatar
go to summitracing.com and search the part# BMM-70264 its a b&m universal kit. It will take some mods to fit but it will work.
