1995 montero throttle position sensor
Old Feb 5, 2018 | 07:56 PM
ScottT's Avatar
Default 1995 montero throttle position sensor
I have a 1995 montero SR, the check engine light is on and the trans AT light flashes continuously. I jumped out the diagnostic plug, code 11, TPS. Tested all aspects per the manual (ground good, wires good, supply voltage good, initial sensor resistance good, but it does not change with rotation?), voltage does not change with throttle position. Replaced with new sensor, same readings. Replaced again with warranted part just in case it was a fluke, same readings.
No engine related issues, the trans TC is not locking up in 4th, I don't have any other error codes, suspect lockup solenoid but I need to correct the tps code first.
What else can I check?
Thanks
Scott
Old Feb 3, 2019 | 08:25 AM
mxmikie's Avatar
change your engine temp sensor
cashcase
13
Nov 10, 2014 06:17 PM
jrmdir
Jun 19, 2010 02:03 PM
bOutty
Mar 30, 2010 03:35 PM
FARDJA
Jun 28, 2005 01:25 PM
art1217
May 11, 2005 09:15 PM
