Constant Short Beeps
Old Jan 11, 2019 | 01:21 PM
SABCD's Avatar
Default Constant Short Beeps
I have a Mitsubishi ASX 2013. This morning I discovered a short beeping sound it goes off about every 45 seconds. It checked to see if it was my seatbelt, hand break or perhaps that my key battery was low (I put my key into the key compartment in the glove box) but so far it doesn't seem like any of those things are causing it. There are also no warning lights on to help indicate what the problem could be. To my knowledge it only goes on when the car is on.
I've attached a video in which you can hear the sound. It's kinda driving me nuts as subtle as it is.
Old Jan 6, 2022 | 11:23 PM
Lucasdif's Avatar
Hello have you worked out what the noise was from?
Old May 6, 2022 | 08:40 AM
ramasa's Avatar
I have the same problem with my car and found out that the beep sounds cause from the censor of your tires. Check your TMPS (dash board monitor) if any of your tire is not properly working. Meaning no tire pressure indicated. If you want to remove the beep sounds, go to service center who installed your TMPS (mine at WinterPine @ Aurora Blvd) and replace the censor or let them deactivate the TMPS. I did deactivation instead due to expensive censor. Hope your problem solved.
Old May 6, 2022 | 09:10 AM
ramasa's Avatar
Yes & it works.
Old Mar 18, 2023 | 06:56 AM
ddff's Avatar
That's really bad news. Go to the repair shop and fix it as soon as possible
Old Jun 6, 2023 | 11:55 PM
MitsubishiRVRWhite's Avatar
Did you ever figure out what caused this? My car is doing the 3 beeps followed by 2 beeps. Nothing on my display to show any errors or issues but the beeps are still there.
SABCD
Jan 11, 2019 01:26 PM
tgND
Feb 25, 2012 06:17 PM
2010CanOutie
Jan 8, 2011 09:40 PM
topgear
Mar 14, 2009 12:20 PM
Emil
Feb 18, 2008 12:38 PM
