Weird "Ticking" Noise???? (Help?!)
Old Mar 3, 2012 | 01:37 AM
DarkPoet's Avatar
Default Weird "Ticking" Noise???? (Help?!)
Here's some information on the car:
It's a 1996 Mitsubishi Galant, I keep getting persistent "check engine" lights with the error code of P0304 cylinder 4 misfire. The mechanic I took it to said it's likely to be a dirty fuel injector issue and to try to run some cleaner through it. The car has a bit of a hard idle and "ticks" as you will hear in the video. I'm wondering what exactly is this? It doesn't sound like it's coming from the engine to me but a bit behind it???
Thoughts??
100_2216.mp4 video by mDarkPoet - Photobucket
Old Mar 3, 2012 | 07:45 AM
mxmikie's Avatar
its called tappet tick mitsubishi is famous for it
Old Mar 3, 2012 | 01:51 PM
DarkPoet's Avatar
Tappet tick? I don't know what that means XD
Old Mar 5, 2012 | 07:37 AM
mxmikie's Avatar
hydraulic lifter tick "tappet"
Old Mar 5, 2012 | 03:04 PM
DarkPoet's Avatar
OH, that makes sense now, thank you
Is there any possible correlation with the lifter tick and the cylinder misfire? I have a suspicion it could be one of my pushrods as a friend suggested but I'm not certain. O_o
Old Mar 5, 2012 | 06:34 PM
mahusay's Avatar
Unlikely, 3kgts are known for lifter tick as well. It's oil related, shouldn't cause misfire
Old Oct 2, 2013 | 10:34 PM
Spencerrose's Avatar
Angry Clicking/ticking in the engine
I have a 2000 eclipse gs 1.4 and i have a ticking/clicking noise coming from the engine. It comes and goes but its back and louder than ever? I know i have a engine mount broken but i know what that sounds like and this is completely different. Any ideas? Also suggestions on how to get more out of my performance without paying alot of money???? Thanks.
Old Dec 8, 2013 | 04:41 AM
Biskitking's Avatar
A broken motor mount can actually amplify motor noises as the rubber deteriorates and becomes metal to metal contact at the mount. The "tappet" noise can be lessoned by using and engine flush to break down the paraffin, varnish, and lacquer that builds up inside the engine. I personally do not like the aggressive cleaners like B-12, too harsh and too much of a possibility to get bearing wash and lunch the crankcase. I have used ATF and Seafoam and had good results.
Old Aug 23, 2014 | 05:09 PM
Chaspalm's Avatar
Default Try this
I use 1 cup of Marvel Mystery Oil about 1 week before I change my oil to break down deposits and crud. I have used it in every car or truck I have owned. It will help with you lifter chatter also.
Charles
jsevinsk
Aug 14, 2022 10:36 AM
Corbul
Jan 8, 2015 08:43 PM
firstorbit84
Apr 2, 2011 06:24 PM
treasguy
Jan 28, 2010 07:15 PM
