suspension?
Old Feb 17, 2008 | 07:50 PM
rses's Avatar
Default suspension?
i have an 02 Mitsubishi Lancer ES.
i have a prob. w/ my car. when i drive slow through a bumpy road, i hear something bouncing from my my driver side. i didn't put any aftermarket coilovers nor lowering springs. all stock suspension. what may cause this noise?
Old Feb 17, 2008 | 08:20 PM
dsm1990gsx's Avatar
Default RE: suspension?
You probably have a bad sway bar link, take it to a shop and have them check thefront endfor any kind of play.
Old Feb 18, 2008 | 07:01 AM
A sway bar link isnt gonna cause play in the wheel. At least i couldnt see how. But a bad link will definitely cause some rattling. It could be ont of many things that make noise in the suspension though. Could be blown strut, ball joint, sway bar link, something could be loose
Old Feb 18, 2008 | 02:29 PM
dsm1990gsx's Avatar
ORIGINAL: TheEngineer
I agree that a link wont have play thats why he should takeit to a shop to check the FE out to see if he has any play, like you said from a tie rod or balll joint.
Old Feb 25, 2008 | 07:28 PM
rses's Avatar
what is FE?
Old Feb 25, 2008 | 07:52 PM
dsm1990gsx's Avatar
ORIGINAL: rses
what is FE?
front end
Old Feb 29, 2008 | 04:47 PM
rses's Avatar
got the problem fixed.
my strut was loose...tighten that shhhhh...up~
miche77e
Oct 31, 2005 12:16 AM
Galantz01
Feb 19, 2005 04:43 AM
mrgordijev
Feb 5, 2005 05:58 AM
ivanejackson
Oct 11, 2004 12:07 PM
jacek
Jun 16, 2004 07:02 PM
