Replaced O Sensor, Now shaking
I have an 05 Endeavor with 90k miles on it. Last week the check engine light cam on. Scan said oxygen sensor, which we replaced. After replacing it, the car started to "shudder" a little bit when going uphill and applying minimal gas. Can the replaced sensor cause this?
I've read about the torque converter shudder too and the symptoms sound the same but I have a hard time believing that it coincidentally started the same day the sensor was replaced. What do you think?
Hello!
Did you find what the problem was?
I have an 05 Endeavor as well and had the same problem but started way before the check enginge lit up. I already took it to the dealership and they found nothing wrong with it (in the computer i guess) but the shaking problem still persists, they even told me that could be dirty gas or something but i have emptied the tank so many times that im sure thats no it.
Was it the torque?
thnx in advance!
My mechanic thought that it was a simply a miss and wanted to start by changing the plugs and filters and move on from there if it didn't work. We wound up trading the car in because it was starting to do different things that were making us nervous and it was our "good" car. We really liked the car up to about 80K miles. We're now the owners of a new KIA Sorrento. Sorry I couldn't be more help.
shaking fixed
after reading a lot of posts a frien sent me this link:
2004 Mitsubishi Endeavor: vibration..driver side..35-40 mph..1500 rpm - JustAnswer
so i printed it and went to the mecanic and he immediately knew the problem... he just changed the transmission fluid or something like that (S3 oil or something) and put in this as well:
Dr. Tranny Instant Shudder Fixx
problem solved!!!!! worked like a charm he charged me 100 bucks instead of 1300 another mecanic wanted to charge because he wanted to check the transmission
hope it help someone else...
adamsstreetauto
02-23-2018 05:43 PM
ajl44
03-23-2014 10:04 AM
