1995 Montero LS - 3.0 need column light switch plug diagram
I’m trying to troubleshoot a short that melted the fuse to the fuse block under the hood and the wire that killed my dash lights and tail lights (still have headlights and blinkers and brakes).Checked the usual so I’d like to check the column light switch by jumpering the correct connectors to see if the lights come on which will tell whether it’s the column switch or something else.I’m hoping someone has the diagram that tells you:
~ which of the three plugs in the column switch is to be tested?
~ which of the connectors in the plug is the hot for jumpering?
~ which of the connectors in the plug is for the tail lights?
~ which of the connectors in the plug is for the dash lights?
Here’s what I found that gave instructions on jumpering but it’s for a GM:http://troubleshootmyvehicle.com/gm/4.3L-5.0L-5.7L/headlight-switch-test-3
If you have any other suggestions for testing I’d appreciate it.I’m in Costa Rica without access to dependable tech/service guys and hard to come by for parts.Testing before I buy and have it sent down to Costa Rica is much preferred.
Thanks in advance.
Thanks in advance.
jallert
06-09-2012 10:21 PM
blazingdisciple
09-12-2010 05:45 PM
Dumbo45
01-23-2009 09:29 AM
lbc_rider
04-25-2008 10:48 PM
