HID Conversion DONE! (Pics and info)
Old Sep 28, 2010 | 07:59 PM
  #101
eurojet's Avatar
Originally Posted by ontariotibv6
Do not do this mod to the harness, it will melt the wires and surrounding plug!
so i did the above mod ,switching the wires from the headlight harness and it seemed to work fine, but just tonight my wife came home (here Outie) and said her car is making a funny noise.
(short back ground , I installed foglights and wired it to the parking lights as the trigger for the foglight relay, this was done so that she never forgets to turn them off and i did not have to install a switch)
so when the noise finally came oni traced it back to the relay for the foglights, the only reason why i can think this would happen is because it is not getting a full 12 volts
any thoughts
Old Sep 29, 2010 | 05:27 PM
  #102
serego's Avatar
any thoughts
Well, once you switched the wires - your parking light circuit is no longer producing 12V!!! It does produce constant 12V prior to modification and this is why I switched them, so that I can use it for low beam HID relay. In your case, you shouldn't do this mod - just wire-tap fog lights relay to stock parking lights wiring. BTW - if you have not switched to HID relay kit for low beam, your parking light circuit is now been overloaded by stock low beam lights - beware!
Old Sep 30, 2010 | 09:07 AM
  #103
User 61220's Avatar
For those of you that replaced your fogs, how did you do it? I can't seem to get any good openings to get my arm in and do it.
Old Oct 1, 2010 | 03:45 PM
  #104
eurojet's Avatar
everything is switchback to the way i first had it. I am for sure running a HID relay kit would not install it with out one
and jaysfreak i took the bumper off to install the foglights
Old Oct 7, 2010 | 05:51 PM
  #105
armymen's Avatar
i have a question,
is there a normal light bull i can put without do a HID convertion ? and have a WHITER light ? But still see good ?
Old Oct 7, 2010 | 06:37 PM
  #106
RAMON-'s Avatar
Originally Posted by armymen
i have a question,
You asked the same question here https://mitsubishiforum.com/forum/sh...ad.php?t=36861
and I answered it for you. I tried to help you and did everything but purchase the bulb and install it for you. wtf
Cool but probably still need to MOD my light for that ?
I ask more detail from the company will see what they say
The owners manual says that the low beam bulb is 9006HB4. I believe that if you can find that type of base/plug, you should be good to go. It is a common base. Good luck!
This should help.
http://www.lightbulbs4cars.com/site/1567293/page/823788
__________________
so theire is no different light i can put with a more white
what kind of mod i need for the HID?
can the dealer do the change ? costly ?
kind of look wierd now led ligh like a audi its ok but with the park light LED with the normal yellow light look funny :s
My buddy has these type of bulbs.
They arent too bright and look cool.
http://www.coolights.com/Headlight-Bulbs_c_233.html
Last edited by RAMON-; Oct 7, 2010 at 06:48 PM. Reason: Adding redundant information. Posted elsewhere
Old Oct 7, 2010 | 06:51 PM
  #107
armymen's Avatar
Talking
This should help.
__________________
haa sorry lol
im stupid haha ;P
So an other question
from that website, http://www.lightbulbs4cars.com/site/1567293/page/823788
Crystal White that is white like a LED light or HID like right ?
( before i order and cry because wrong colors, lol )
it also say : FOR OFF ROAD OR SHOW ONLY . ????
And are they as bright when i drive as the factory one ? As perfomance ?
thanks again :O
Old Oct 7, 2010 | 06:58 PM
  #108
RAMON-'s Avatar
haa sorry lol
im stupid haha ;P
thanks again :O
Hehehe
I believe they are. It would be great for the manufactures to have a standard name and description for their bulbs. Its kinda confusing. Just my opinion....for low beams keep they 55 watt or under. this link may be more helpful.
http://www.lightbulbs4cars.com/site/1567293/page/926443
Here I a nice description....
http://www.lightbulbs4cars.com/site/...roduct/CWHB455
Old Oct 7, 2010 | 07:19 PM
  #109
armymen's Avatar
Hehehe
So why people take the time to convert to HID light ? If they can achieve the same with that bulb ?
yes its kind of confusing
Old Oct 7, 2010 | 07:38 PM
  #110
armymen's Avatar
so i order
9005/HB3 12V 65W Crystal White
9006/HB4 12V 55W Crystal White
50$ CAN to ship to canada
for the park light W5W i already have LED bulb so everything will look nice with everything
thanks
