Old Jun 2, 2008 | 11:30 AM
  #121
brian360's Avatar
Any mitsubishi updates will replace the dvd-in-motion patch. Updated maps must be ordered. CDDB and firmware (non-map) updates are free.
Old Jun 2, 2008 | 11:35 AM
  #122
lancer17's Avatar
Oh ok, so in theory you should just be able to use the same dvd-in-motion patch disk again after doing a mitsu update?
Old Jun 2, 2008 | 12:30 PM
  #123
brian360's Avatar
Chances are, a mitsu update will give you a newer version than we currently have patched for dvd-in-motion. So chances are we'll need Otaku to prepare a patch for the new version that you can finally create a new patch disc for.
Old Jun 2, 2008 | 01:22 PM
  #124
badboyid's Avatar
I think you guys are doing a great job. I was wondering if this patch would work on my japanese language mmcs?
Old Jun 2, 2008 | 01:36 PM
  #125
lancer17's Avatar
ORIGINAL: brian360
The only way to really know then is to update and see what changes then :-P
Old Jun 2, 2008 | 02:00 PM
  #126
jsrd's Avatar
ORIGINAL: badboyid
I believe that if the version LOADER and APPLICATION that your MMCS has are the same ones that has patcheado Otaku (261UM v109/2068, and 261EM v109/111) would have to work, otherwise, it is necessary a patch especify for your version of MMCS. . .
Old Jun 2, 2008 | 02:47 PM
  #127
eddz's Avatar
[quote]ORIGINAL: brian360
You mention you were going to update your navigation. I suggest that you update that first, then give us a copy of the CD/DVD (or specifically the loading.kwi and alldata.kwi files from the disc) and we can probably patch it directly from that -- no pulling of the HDD necessary. (assuming that your navigation update gives you version 00.30.94)
so is that mean we only give u a navigation update disc and u guys can do the patch thru the disc for 00.30.94 version?
Old Jun 2, 2008 | 03:17 PM
  #128
ibstudent's Avatar
You guys are amazing! I tried it out last night and it worked like a dream.
Just out of curiosity, what are you using to edit it? I'm not the greatest programmer, but I havebasic experience with a handful of languages andwith the right tools and a little luck I could probably figure some of this out too.
Old Jun 2, 2008 | 03:23 PM
  #129
brian360's Avatar
ORIGINAL: eddz
Depends on what version the navigation update disc gives you. After you install the navigation update, check the version on the MMCS itself. If it is a version that we have not yet patched (i.e. 00.30.94), then, yes, send us the disc so we can make a patch
Old Jun 3, 2008 | 05:35 PM
  #130
Mitsu_Fizzle's Avatar
To get hings off the HDD (30.94 stylee), will I need this....
http://www.compusa.com/applications/...&CatId=448
or this..
http://www.compusa.com/applications/...&CatId=470
Your input is appreciated.
Btw, if both will work... which will be the safest/easiest one?
