Old Nov 19, 2011 | 11:38 AM
  #1121
WiValdiBB's Avatar
Originally Posted by dokjones
first, great work on the patching, nice to see this kind of community, WiValdiBB you're awesome. I'm trying to find out if there is an in-motion patch for:
261-UM 1.09
App: 60.09
Thanks in advance for the info
Sorry, Apps 60.x EM or UM are not cracked yet
Old Nov 19, 2011 | 12:52 PM
  #1122
exttortion's Avatar
thanks man , goes well
Old Nov 21, 2011 | 05:29 PM
  #1123
Zedicus's Avatar
heres some more kwi extraction code. i got this running but was not relevant for the outlander nave. may help some of you guys that are having issues with the other kwi extractor...
anyone have a cloning machine? i would be all over this if i had 2 or 3 of me...
File Type: zip
Old Nov 22, 2011 | 02:59 AM
  #1124
WiValdiBB's Avatar
THX man
Old Nov 24, 2011 | 03:59 PM
  #1125
spoondoggie's Avatar
Default Any luck with...
a DVD in motion for BLD-NR-261UM 1.09 Application 40.02?
You guys are doing an amazing job!
Old Nov 25, 2011 | 03:07 AM
  #1126
WiValdiBB's Avatar
The only way for You is:
Unlock HDD and then replace loading.kwi with UM 30.99 and reinstall system ( HDD Load MMCS )
Old Nov 27, 2011 | 11:31 PM
  #1127
Zedicus's Avatar
not a detailed list. BUT it is fairly small so it should not be hard to make the changes. the hardest part will be FINDING where these keys have moved to in the new 60 series of loading.kwi files.... this compare utility is kinda handy. not near what my actual editor can show but a VERY fast efficient way to find the actual differences.
Compare error at OFFSET 93
file1 = 35
file2 = 34
Compare error at OFFSET D3
file1 = 35
file2 = 34
Compare error at OFFSET 568BA3
file1 = 5B
file2 = E5
Compare error at OFFSET 568BA4
file1 = 1D
file2 = 20
Compare error at OFFSET 6549A7
file1 = B
file2 = 86
Compare error at OFFSET 6549A8
file1 = 0
file2 = 2F
Compare error at OFFSET 6549A9
file1 = 9
file2 = 22
Compare error at OFFSET 6549AA
file1 = 0
file2 = 4F
Compare error at OFFSET 6549E3
file1 = B
file2 = 86
Compare error at OFFSET 6549E4
file1 = 0
file2 = 2F
file 1 was a nodvd loading.kwi
file 2 was a box stock loading.kwi
Old Nov 30, 2011 | 06:25 PM
  #1128
misiak's Avatar
Hi
at first, big thank on the work you done here.
I just got my Peugoet 4007. And as you know, it has the MMCS as outlander. I looked at the version and got a little surprice...it has app. version 20.04 with really old maps.
I didn't find any nodvd for this version. So I thought, I will update it to never one, let's say 50.12 I found here. I hope, I'm guessing right few things:
1. it will work - just overwriting the loading.kwi and alldata.kwi will update this to new version
2. I can update maps to latest (shouldn't be a problem, I hope)
3. if I turn on the MMCS, there is a starting animation...at this moment, It's peugeot. By using the loading.kwi from outlander, will it be still Peugeot or will it change to Mitsubishi?
thanks for replay
Old Dec 1, 2011 | 03:13 AM
  #1129
WiValdiBB's Avatar
thanks for replay
1.Mitsu loading.kwi will NOT work with 4007 MMCS !!! French MMCS systems are not compatible with Mitsu. Strange, but it is I didn't check that personally but I heard that from peoples which tryied to replace loading.kwi. You can try too, please backup Yours files and just check, and confirm it here
2. Maps You can update, by simple replacing existing files
3. That animation is probably inside flash of MMCS, I wanted to change by modifying of loading.kwi but without success
All I know
Old Dec 1, 2011 | 09:05 AM
  #1130
misiak's Avatar
All I know
thanks for the info
I will try to replace the loading.kwi and hope, it works. Of coarse, I will backup it first.
2. great info, will do
3. also a good info, hopefully it will be this way
So, is here anyone, who could send me a newer loading.kwi for 4007?
Thanks
