Sportronic
Old Jul 24, 2008 | 03:44 AM
VancouverMitsu's Avatar
Default Sportronic
hi,, anyone here using sportronic all the time? how exactly do you use it? is it save more gas than the automatic D?
Old Jul 24, 2008 | 08:25 AM
bnilguy's Avatar
Default RE: Sportronic
I rarely use it.. only time I can recall using it is when I take a long onramp curve slightly uphill.. For some reason when I give it a bit of gas it will upshift into 6th..so I just flick the paddle and return it to normal when I get up to speed
Old Jul 24, 2008 | 11:13 AM
azjake's Avatar
I've used it on long downward grades to help keep the speed steady without riding the brakes.Usually when I shift over to sport mode I'm in 6th gear, and when I shift down to 5thit holds the speed steady without braking.
Old Jul 27, 2008 | 08:39 PM
HandyPal's Avatar
Same here, having the same car 2.4L CVT, I use manual shift mode primarily for engine braking or quicker accelerations if really needed.
Old Jul 27, 2008 | 08:40 PM
HandyPal's Avatar
This manual mode will not save any gas for you and that is for sure. Automatic shifting is very optimised for smooth city cruising and you won't see a difference on highway at steady speed.
se7en
Feb 17, 2008 07:27 PM
neo2040
Jul 6, 2007 11:55 AM
eclipse6racer
Jan 2, 2007 08:11 PM
Mattdd
Jul 26, 2005 10:09 PM
khscott
Aug 15, 2004 02:38 AM
