93 2.0 GS 5-Speed - Clutch
Old Sep 12, 2008 | 05:53 PM
tdf's Avatar
tdf
Default 93 2.0 GS 5-Speed - Clutch
The clutch has been in our 93 for about 20k miles now. Even before the new clutch kit, the clutch doesn't always disengage going into first and reverse especially.
This seems to me to be more likely the clutch hydraulic master and slave cylinders rather than the clutch.[:-]
Do you agree?
Thanks for looking!
Old Sep 12, 2008 | 05:55 PM
dsm1990gsx's Avatar
Default RE: 93 2.0 GS 5-Speed - Clutch
Is there air is the sysyem, try bleeding it.
Old Sep 12, 2008 | 06:04 PM
tdf's Avatar
tdf
To clarify, the clutch engages right off the floor and it drags between gears or initially going into 1st at a light unless you double clutch it and press the pedal to the floor hard. Seems to me the pressure plate isn't getting enough push from the slave hydraulics.
Old Sep 12, 2008 | 06:18 PM
dsm1990gsx's Avatar
Try adjusting the clutch master cylinder and also check the clutch pedal, it might be worn out. Push down on the pedal and release it then try to pull up on the pedal. If it moves the pedal assembly is worn.
Old Sep 13, 2008 | 09:17 AM
tdf's Avatar
tdf
So you don't think the slave or the master cylinders are worn out! I would never have thought about the pedal assembly being worn. Thanks for your thoughts and ideas! I have ordered a repair manual.
Old Sep 13, 2008 | 11:12 AM
dsm1990gsx's Avatar
Well if they are not leaking I wouldn't replace them.
Old Sep 15, 2008 | 12:31 PM
^ i think you meant if they are not leaking then i "wouldnt" replace them.
I would start with the clutch pedal adjustment. There is a small bolt on the push rod behind the pedal toward the master cylinder. You have to loosen the bolt, then turn the rod so that it extends the length of play, then retighten the bolt.
Old Sep 15, 2008 | 05:52 PM
dsm1990gsx's Avatar
ORIGINAL: TheEngineer
Thanks I just noticed that lol.
Old Sep 21, 2008 | 10:06 PM
tdf's Avatar
tdf
Well I finaly got my Chilton Manual and started reading the section 7-36 Pedal Height/Free-Play Adjustment instructions. It says that the height of the pedal pad face should be 6.93-7.17 in to the firewall. Hummm
There is no sketch or pic to show how to make that measurement.
Where on the firewall (do they really mean the floor) does one take that measurement from?
Our pedal definitely has way to much Free-Play so I think you guys are onto the problem. I will adjust the pedal free play as instructed in the Chilton. I will also bleed the system. I see no leaks so maybe new clutch cylinders are not needed afterall.
Thanks
95EclipseGS95
Aug 20, 2007 01:03 PM
max3
Jul 21, 2007 04:46 AM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
