Drive Line?
Old Sep 18, 2007 | 11:27 PM
BLAZE GS's Avatar
Default Drive Line?
does any1 know how to take the drive line out of a 93 eclipse FWD need to get trans out to do a replacement like engine. THANKS
Old Sep 19, 2007 | 05:49 AM
nick_200321's Avatar
Default RE: Drive Line?
when i had to take out mine to get my tranny off, i just took apart the whole front-passenger wheel assembly.. it was a pain in the *** and i had to beat on it a little but it got out lol..
Old Sep 19, 2007 | 02:33 PM
ComposeEvo's Avatar
i mean a simple transmission job, as in taking it out?
know that the c.v joint must come off, this is very easy to take off
the starter must come out,
air intake, ( for room to work with)
transmission fluid drained,
speedo, all grounds,
bottom bolts,
shift linkage,
removal of tranny mount bolts, ( know that the side tranny mount must be completly off to remove tranny)
Proper removal of Tranny bolts, including sequence. ( always leave on top to relieve tension of the inputsaft)
and finally, just have a hook, with a rope, slide the tranny off, and place gently on the floor.
If you have any specific questions just ask me and i'll explain in further detail.
Gus
Old Sep 19, 2007 | 08:27 PM
BLAZE GS's Avatar
but i plan on taken the trans out with the engine at the same time.
Old Sep 19, 2007 | 08:32 PM
jason clipse's Avatar
how should i do it to leave the tranny in but take the motor out?? on the tsi
Old Sep 19, 2007 | 09:07 PM
BLAZE.. i dont know if you can do that, i think the wheel well will be in the way, if not i would try using a cherry picker to hold it all up, diconnect mountes, cables, wires, ectect and maybe try pulling it out sideways, but i dont think there will be enough clearence, you might have to take them out sepratley
Old Sep 20, 2007 | 05:23 PM
BLAZE GS's Avatar
this is what im doinName:  IMG_0748.jpg
Old Sep 21, 2007 | 10:16 PM
estraw's Avatar
it would be a lot easier to just unbolt the bellhousing from the engine and it would save you a lot of effort and time
sk8dudety
May 31, 2014 08:55 AM
Wingo171
Aug 20, 2007 05:38 PM
V8killer
Aug 21, 2005 12:57 PM
trbodsm997
Dec 25, 2004 01:52 AM
92diamante
Oct 30, 2004 08:23 AM
