replaced timing belt, now little power
Old Mar 8, 2006 | 01:20 PM
robfrey1's Avatar
Default replaced timing belt, now little power
I have a '94 Eclipse that had a timing belt (or chain?) replaced. Since bringing it home from the shop I have noticed that the acceleration has been weakened. Also, on hills the engine appears to be "pinging". Any ideas before I take it back to the shop? Also, my fuel economy is about the same.
Old Mar 8, 2006 | 01:39 PM
Default RE: replaced timing belt, now little power
What do you mean by pinging. Is it a sound that its making?
Old Mar 8, 2006 | 01:41 PM
ORIGINAL: TheEngineer
He has internet in his engine bay and he is doing a ping test???!!?? lol j\k.
maybe they didnt set the timing properly
Old Mar 8, 2006 | 01:43 PM
ORIGINAL: EMonz57
thats what it sounded like to me, its probably just off enough that it doesn't cause a major problem.
Old Mar 8, 2006 | 04:03 PM
Sanguinius's Avatar
Off by 1 tooth I'm guessing any more and it would be a BIG problem.
Old Mar 9, 2006 | 01:31 AM
My93EclipseGS's Avatar
Sounds like that to me as well. I did a timing belt change on my 93 once and didn't take in to account that I had to take a wrench to the intake CAM to compress the value springs. Anyway my car started but ran like sh#t. So here is what you do. Find a Socket that fits the center of your Crankshaft. Put the engine to TDC (Top Dead Center) and look at the CAMs. They should be a notch on the pullys that is lined up. You will be able to tell. If it is off you will need to take it back to the shop cause they have to tear the whole front part of the engine apart. Good Luck and let us know.
adamsstreetauto
Feb 23, 2018 05:43 PM
exoticwelding
Aug 18, 2009 01:26 PM
cwilhelm
Jun 10, 2009 10:03 AM
Wi_Fibre
Jan 16, 2008 12:17 PM
jmms
Feb 26, 2005 08:57 PM
