4g64 - 4g63
Old Feb 7, 2007 | 01:53 AM
estraw's Avatar
Default RE: 4g64 - 4g63
ORIGINAL: EMonz57
OK let me get in here since I have owned both engines.
The 2G spyder yes it can swap the GST motor in and it can also swap AWD drivetrain in as far as I know Its been done a few times unless they were GSt Spyders swapping in drivetrain, but I always understood it as 4G64 cars since the spyder from what I have seen has the same frame as the GSX due to needing to be stiffend up and reinforced. The only main difference is the crank. Alot of guy actually use a 4g64 crank to stroke their motors. The 3G GS\RS is also a 4g64 but it is single cam and faces opposite the 2G DSM motor. HOWEVER people can swap the Evo head in and it has been done a few times. There is no poit swapping the block your better off for your money to build the bottom end of the 4g64 3G motor and turbo the car so you have a built stroked motor it is really no different from stroking an Evo motor if you swap the Evo head onto the 3g and the power gains end up becoming similar to an Evo minus the traction help of AWD
do all of the generations of evo's heads swap onto the 3g 4g64? or just a certain gen?
Old Feb 7, 2007 | 02:29 AM
silvercoupe97's Avatar
Ask and you shall receive...info that is
Tuner's info....you know what to do.
The 2.4 L 4G63
Talk info.
7 bolt 4G64 build up w/ DOHC head
Club DSM Southwest
Project 4G64
This info goes towards the Spyder with a 4G64 also, or any car with a 4g64.
There's a lot more info on this than that, but that should get you started.
Old Feb 7, 2007 | 02:34 AM
97spydergs's Avatar
cool Thanks alot
Old Feb 7, 2007 | 10:34 AM
RCJr9186's Avatar
good stuff. YAY Ron is on a learning curve with Spyders... lovin it!
Old Feb 7, 2007 | 10:50 AM
ORIGINAL: estraw
ORIGINAL: EMonz57
no just the Evo VII VIII and IX
Old Feb 7, 2007 | 04:00 PM
...and EVOs 1-3...since they are the same 4G63 heads as the Eclipse/Talon
Old Feb 7, 2007 | 05:39 PM
TheAdvocate's Avatar
Ive seen a couple 3gens that had the evo heads on them... It caught me off gaurd at first, but looks better than just the regular head on it..
Old Feb 7, 2007 | 07:01 PM
ORIGINAL: silvercoupe97
well not the 3G though.... he asked about the 3G GS|RS which can only take the VII VIII and IX head
frakinstine
Nov 4, 2005 02:02 AM
frakinstine
Nov 1, 2005 03:25 PM
926bolt4g63talonnt
Jul 9, 2005 04:44 PM
Waters411
Jul 8, 2005 11:06 PM
Black98
Mar 30, 2005 07:23 PM
