Can I Power shift or hard shif?
Old 06-22-2007, 01:45 PM
Default RE: Can I Power shift or hard shif?
Then its either your master or slave cyl. If adding more fluid and pumping it didnt work.... it should work within like a min of pumping it. How long did you sit there pumping it for? Did you notice anything under the car?
Old 06-22-2007, 01:52 PM
nyc95gst's Avatar
Yea that's what I had read in other posts (which, funny enuff, you are in also) that it was either master or slave. I was going to check lines for leak, bleed, then replace both parts.
I didn't pump it that long. I think I should try and pump it again. I also didn't look under the car. It had rained a little or something and the street I was on was slick.
If pumping it doesn't work, does that mean it's proly one of the cylinders?
If pumping it works, what does that mean?
Old 06-22-2007, 01:57 PM
If pumping it works then it means you just didnt have eough fluid. Fill up the reservoir and pump the clutch for like a min. If you dont have pedal pressure back by then, then the master or slave is out.
Old 06-22-2007, 02:06 PM
nyc95gst's Avatar
Thanks Sebba.
One more thing, if it's one of the cylinders, should I be able to put the car in gear while it is off? I guess what I am asking is if I can't, does that mean the clutch/tranny is F$%k$% ?
Old 06-22-2007, 02:13 PM
You should be able to get it in gear with the car off.. yes. If you cant then you may have another problem
Old 06-22-2007, 02:19 PM
nyc95gst's Avatar
Thanks man, I'm off to go fix this thing. I'll let you know how it goes if you wanna kno.
Thanks again man.
Old 06-22-2007, 09:40 PM
nyc95gst's Avatar
Alright Sebba,
Pumping it worked. I really didn't think you had to pump it that much, but whatever. So long as it works. Now I have to check and see where there might be a leak. Is it true it's usually the slave cylinder?
Anyways, thx man.
Eclipse440
07-14-2015 11:08 PM
pinoyjetpilot
07-15-2011 02:25 AM
sandygarf
08-27-2008 12:04 PM
mr.lover21
12-14-2007 10:47 AM
clipzegal
01-02-2006 10:02 PM
Quick Reply: Can I Power shift or hard shif?
