can't shift
Old Aug 21, 2008 | 10:24 AM
sandygarf's Avatar
Default can't shift
I have a 2003 Eclipse with a 5 speed manual transmission. The **** that I hold to change gears is very "loose". I can move it very easily all around. I can get the car into 1st gear, but not much else. Does anyone have an idea of what it could be and how to fix it? Thanks.
Old Aug 21, 2008 | 11:21 AM
Default RE: can't shift
pull off the center console. There is probably a loose shift linkage or a loose bolt.
Old Aug 27, 2008 | 12:04 PM
guilianno88's Avatar
i dont know much about cars, but i know that the shifter is connected to wires, and when you put it into a certain gear, the wires is what change the gears your in.
so maybe some of your wires connected to your shifter is busted and not pulling right.
good luck to you though.
Eclipse440
Jul 14, 2015 11:08 PM
StanJarensky
Feb 21, 2013 11:12 AM
ruski
May 4, 2009 09:24 PM
nyc95gst
Jun 22, 2007 09:40 PM
nyc95gst
Jan 13, 2007 07:34 PM
