car starting bad
RE: car starting bad
i wanna say its clutch related cause when it turns on the belts sqealing but also theres like a humming noise..but when i push my clutch in it stops for a second then it comes back......my mechanic said it was starting bad cause my alarm went bad and i guess triggered the kill switch he also said that replacing the alarm would fix it..but that just be it theres gotta be somethin up
well the belt squeeling is either a loose belt or belt that needs changed.. or a loose belt that needs changed lol.. when you start it... does it like, start to crank then go into a very loud squeel and you have to try again?? if so your starter is probably shot..
what up everyone,I have a 95 eagle talon tsi and having trouble starting the car.i did a engine swap
lemie585
10-25-2008 06:02 PM
matt02708
05-11-2007 10:18 PM
