car starting bad
Old Nov 11, 2007 | 04:13 PM
spyder4g63t's Avatar
Default car starting bad
starting bad lots of noise..takes 5 min to get it started....squealing noise//
Old Nov 11, 2007 | 05:53 PM
dsm1990gsx's Avatar
Default RE: car starting bad
Belt squealing noise or like starter meshing w/ flywheel noise? Check your fuel pressure when it acts up.
Old Nov 11, 2007 | 08:25 PM
TheAdvocate's Avatar
takes 5 minutes to get started? You mean it takes 5 minutes for the squeling to go away? If thats the case, its prolly just a belt that needs to be replaced..
Old Nov 12, 2007 | 06:57 PM
i wanna say its clutch related cause when it turns on the belts sqealing but also theres like a humming noise..but when i push my clutch in it stops for a second then it comes back......my mechanic said it was starting bad cause my alarm went bad and i guess triggered the kill switch he also said that replacing the alarm would fix it..but that just be it theres gotta be somethin up
Old Nov 12, 2007 | 10:20 PM
nick_200321's Avatar
well the belt squeeling is either a loose belt or belt that needs changed.. or a loose belt that needs changed lol.. when you start it... does it like, start to crank then go into a very loud squeel and you have to try again?? if so your starter is probably shot..
nawgee
Oct 20, 2008 06:24 AM
galant2001
Apr 4, 2008 01:50 AM
matt02708
May 11, 2007 10:18 PM
agallardo
Oct 1, 2006 02:07 AM
