Clutch
Old Nov 30, 2005 | 05:59 PM
get435's Avatar
Default RE: Clutch
try bleeding the clutch also check the master and slave and make sure there are no cracks or anything like that in it.
Old Nov 30, 2005 | 09:51 PM
eclipsed4u's Avatar
Default RE: Clutch
ORIGINAL: get435
the master and slave cylinders have already been replaced.
Old Nov 30, 2005 | 10:02 PM
DSMTalonAWD51's Avatar
Default RE: Clutch
you may just need to bleed the line better. There is a specific spot in the line that is very tricky to get the air out of. If the pedal sticks to the floor after shifting gears only during left hand turns, you need to worry about crankwalk. But if it does it during just normal driving or right turns too, its air in the lines.
Old Dec 1, 2005 | 10:00 AM
get435's Avatar
Default RE: Clutch
ORIGINAL: eclipsed4u
ORIGINAL: get435
regardless of how new they are dose not mean the housing was not cracked durring install or if bolts are not fully sucrured just remember they are made of freaking plastic not metal. this happened on my last car and it turned out to be a small crack where the master i beleve it is bolted to the firewall.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
