Clutch problem
Old Mar 2, 2006 | 08:25 PM
jeffery0266's Avatar
Default Clutch problem
I don't know if I have a problem with the clutch or not,I got a 95 rs and I think that the clutch pedal is too close to the top.Is this a sign that I am about to replace the clutch or is there a tensioner somewhere that I could adjust?
Old Mar 2, 2006 | 09:35 PM
Sanguinius's Avatar
Default RE: Clutch problem
What do you mean too close to the top? Do you have alot of pedal play before the clutch engages? Or does it start right away when you hit the pedal?
Old Mar 3, 2006 | 12:17 AM
eclipseonjuice's Avatar
Need to be a little more specific i dont really understand the problem.
Old Mar 3, 2006 | 12:40 AM
When I have the clutch pressed all the way down and I start to pull out the pedal is close to the top before it starts to pull
Old Mar 3, 2006 | 12:29 PM
well there is a bolt right behind the pedal that you can adjust the pedal hieght. When you floor it at high RPM's does the clutch slip?
Old Mar 3, 2006 | 05:38 PM
Not that I am aware of,I don't think I have floored it and felt it slip,just like I said,the clutch catch's with about 2 inches left to the top of the pedal.No slippage that I know of or felt.
Old Mar 5, 2006 | 07:28 PM
well then you can just adjust the pedal hieght. Right behind the pedal there is a threaded screw with a bolt closest to the pedal. Loosen the bolt, then turn the threaded screw one way or the other, i am not sure which, tighten the bolt back up, and see if it helped. You only need to turn the screw very slightly though. Just kinda do a guess and check with it.
97spydergs
Oct 29, 2007 02:14 PM
95EclipseGS95
Aug 20, 2007 01:03 PM
bud660r
Dec 23, 2006 07:30 PM
wicked2407
Oct 25, 2006 06:07 PM
gsx man
Mar 22, 2005 03:07 AM
