Fuel problems I think...Help
Old Nov 3, 2006 | 06:44 PM
badass91hatch's Avatar
Default Fuel problems I think...Help
98GST spyder.Its done this most of the time i owned the car.At first i only noticed it when fuel level was low and i would take a turn fast while standing on the gas,the dam thing would like completely fall on its face,like it was not getting fuel.It would only do it for a spilt second at a time and basically chug back and forth from WOT to nothing while in the turn.So i was thinking,dam fuel sloshing around in the tank with a low level like less than 1/4 was not reaching the fuel pump.So i dealt with it,now it does it no matter how much fuel i have in the car when making a turn fast while on the gas.And the other day i was in 2nd gear at like 35-40 mph and then hit the gas to the floor,it accelerated for a second then fell on its face like it would in a turn.It only did it once for a second,then kept accelerating,I was also going straight when it did this.I happen to think the fuel pump is taking a crap,and maybe i need a fuel filter change.Any other ideas?And would it hurt to go ahead and upgrade to a 255 with stock injectors for now?Kill 2 birds with 1 stone you know?Let me know....
Old Nov 7, 2006 | 01:30 AM
Default RE: Fuel problems I think...Help
I cant believe no one has a thing to say to help me out with my issues[&o]
Old Nov 7, 2006 | 01:36 AM
Nubiebubie_GSX's Avatar
If you believe that the problem. Just do it anyways. Consider it an upgrade and if it doesn't fix the problem. Its an upgrade for the future lol.
Old Nov 7, 2006 | 09:56 AM
RCJr9186's Avatar
you can pick up an walbro 255 for like 100 bucks, why not. fuel filter replacement is always a good idea if you havn't done it in a while... this wouldnt be the full problem but could add to the problem - check your air filter, plugs, wires.
Old Nov 7, 2006 | 07:48 PM
Stupid question but where is the fuel filter on that car??
jp2000
Jan 1, 2012 05:21 PM
kuyabinid
Other Mitsubishi Models
Dec 22, 2010 01:32 PM
arielrojas
Mar 8, 2008 09:24 PM
AzAuto
Oct 22, 2007 10:31 PM
95Eclispeingarage
Feb 18, 2007 10:07 AM
