Fuel problems I think...Help
98GST spyder.Its done this most of the time i owned the car.At first i only noticed it when fuel level was low and i would take a turn fast while standing on the gas,the dam thing would like completely fall on its face,like it was not getting fuel.It would only do it for a spilt second at a time and basically chug back and forth from WOT to nothing while in the turn.So i was thinking,dam fuel sloshing around in the tank with a low level like less than 1/4 was not reaching the fuel pump.So i dealt with it,now it does it no matter how much fuel i have in the car when making a turn fast while on the gas.And the other day i was in 2nd gear at like 35-40 mph and then hit the gas to the floor,it accelerated for a second then fell on its face like it would in a turn.It only did it once for a second,then kept accelerating,I was also going straight when it did this.I happen to think the fuel pump is taking a crap,and maybe i need a fuel filter change.Any other ideas?And would it hurt to go ahead and upgrade to a 255 with stock injectors for now?Kill 2 birds with 1 stone you know?Let me know....
you can pick up an walbro 255 for like 100 bucks, why not. fuel filter replacement is always a good idea if you havn't done it in a while... this wouldnt be the full problem but could add to the problem - check your air filter, plugs, wires.
kuyabinid
Other Mitsubishi Models
Dec 22, 2010 01:32 PM
arielrojas
Mar 8, 2008 09:24 PM
