low oil
RE: low oil
ORIGINAL: eclipsed4u
if your oil is low and you are under 1500 miles since your last oil change....then you need to get that oil leak checked
ORIGINAL: TheEngineer
to me as long as its under a quart adding some is ok. It really won't effect anything. I guess it also depends on how long its been since the last change. after 1500-2000 you might as well do it.
drain it all, then fill'er up. i have never been a fan of adding oil in between oil changes
RE: low oil
I had it looked at this tune up place next to my work and they said it was my oil pressure switch and a sliced gasket. so thanks for the input but i do know when to change my oil i know that much hahahah thanks
RE: low oil
ORIGINAL: novetek
I drive a few hundred miles and start feeling like it has been forever and I go change it...always ends up being like 1500Miles or so lol
RE: low oil
ORIGINAL: novetek
YEAH ILL PROBABLY CHANGE MY OIL ITS N NEED OF A TUNE UP I WAS JUST WONDERIN IF I SHOULD JUST ADD A LIL THANKS ALOT
