major n00b alert
Old Jun 27, 2007 | 06:59 PM
foetus ennvy's Avatar
Default major n00b alert
i own a fairly rusted 95 eclipse gs, manual.
anywho, i am really quite inexperienced with automototive repair, but have been trying to learn the ropes so to speak. there are a few things i have not been able to pinpoint and i was wondering if you all might be able to lend your suggestions...
1. _slow_ turning of the wheels in a stopped position or at a slow speed (15mph or less?) causes a really horrible grinding/groaning sound. turning the wheels quickly makes no odd sounds.
2. there is a hissing/squealing/whining sound at higher rpms (3500-4500+) in 2nd, 3rd and 4th... not always though, only when the accelerator is close to or fully depressed. if i am easing it up to higher rpms it doesn't make this sound.
3. one of my radiator fans died. i'm assuming wiring, but wondering if this is a common issue
4. my oil pan gasket is leaking. does anyone have any online tutorials or pointers on dropping the oil pan?
thanks so much for your input! owning a busted eclipse has been quite the adventure/learning experience.
Old Jun 27, 2007 | 08:38 PM
Default RE: major n00b alert
1) Wheel bearings
2) Its the sound of your intake
3) Either the fan, a wire harness.. or the thermostat
4) Just inscrew the bolts and change the gasket.. nothing complicated
BigBob
Nov 5, 2007 05:27 PM
Maximus99
May 3, 2006 03:47 PM
Maximus99
Mar 2, 2006 12:58 PM
robvan
Nov 13, 2004 03:15 AM
WickedxCurves
Aug 10, 2004 01:42 AM
