NEED HELP PLEASE~NEWBIE
Old Dec 5, 2004 | 06:51 PM
SpyderGS's Avatar
Default RE: NEED HELP PLEASE~NEWBIE
Yeah, they actually connect into your obd system(obd2 equipped cars only, 1996 and newer) and take check to see if any emmisions devices are malfunctioning or not. Basically, nowadays, the MIL only comes on for emissions related equipment failure. There are quite a bit of other dummy lights in the dash now because of this.
Old Dec 6, 2004 | 12:37 AM
vertstanggt's Avatar
Ahhh, alright, so now what I said doesn't work at all, lol. But that is def something I'm happy to not know about since all they do here in NH is look to see if you have a cat on there. When I bought my mustang it had them hallowed out but they were still there visually so I could pass wherever. Then I got an off road X-pipe for it and passed at a garage I used to work at, he goes, "if anyone asks you put that on tomorrow."
Old Dec 19, 2004 | 06:33 AM
midnght's Avatar
Here in Maryland you can get a 2 year waiver if your car will not go over the rollers because of ride hieght.
Coilovers are your friend, lol.
Old Dec 19, 2004 | 06:41 AM
Playboy4ll23's Avatar
The same engine light is on in mine and its because I need an O2 sensor...maybe thats it
Old Dec 19, 2004 | 06:47 AM
midnght's Avatar
Def. the culprit. The o2 will send false readings like nobody business. Replace it and then reset the ecu by disconnecting the battery for 5-10 mins. Start it up and drive it around. Should do the trick.
Old Dec 23, 2004 | 03:43 AM
way2slo's Avatar
yeah, but if the sensor is actually bad, the light doesnt take too long to come on. My battery's been disconnected several times in the past couple weeks (parked) and the light comes on pretty quick. Anyone know how much a diagnosis test costs? I've had enough of this light
Old Dec 24, 2004 | 09:45 AM
get435's Avatar
go to autozone they will do it for free my sugesstion got to 2-3 to get a for sure reading.
Old Dec 25, 2004 | 12:53 AM
midnght's Avatar
My suggestion is take some of your christmas money and go to
www.pocketlogger.com
Buy the software and cable, then go to ebay and find the cheapest Palm m105 to run it on. This tool will not only tell you what the light code is coming up, but will also help you tune your car by showing you what is going on temp/time/volt wise with the engine. It does not offer a tune feature, just a basic diagnostic in REAL TIME.
Ninjobitch
Aug 21, 2013 12:35 AM
ukiltmybrutha
Jun 19, 2011 03:06 PM
crazyeman1
1st Generation
Feb 27, 2008 07:13 PM
tiller801
1st Generation
Feb 14, 2008 10:25 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
