new car questions
Old Aug 29, 2007 | 11:05 PM
jethro's Avatar
Default new car questions
just bought a 98 GS-T spyder with a possiblyjunk motor. i am needing to find if there is and what is thedifference between 4G63T and 4G63. also will a 1st gen. bolt in directly? i don t want to purchase the wrong motor. THANKS
Old Aug 30, 2007 | 12:01 AM
Default RE: new car questions
The T is turbo.. and internally the engines are different.
A 1st gen (AKA 6 bolt) will bolt in with minor adjustments (search for 6 bolt swap and you will find the list needed)
Old Aug 30, 2007 | 12:03 AM
sk8dudety's Avatar
well all the "T" stands for is "Turbo". And there is a list of mods on here somewhere for the 1g swap... lemme see if i can find it
woop, seb beat me to it, we must have posted at the same time... anywho, hear's the link to what you're lookin for https://mitsubishiforum.com/m_155892/tm.htm
Old Aug 30, 2007 | 03:24 AM
racerx55's Avatar
like they said T for turbo motor, the non turbos have higher compression pistons of course, just be sure to get a turbo motor unless your gonna rebuild it, then you can get pistons to go with what your doing.
6 bolt swap is easy for the most part, go for it.
whats wrong with the motor in the car?
Old Aug 30, 2007 | 07:37 AM
ORIGINAL: sk8dudety
or you could have gone to the eclipse FAQ section that has a post on it
Old Aug 30, 2007 | 09:50 AM
RCJr9186's Avatar
also not all 1g engines are 6 bolt. the 89-92.5 are 6 bolt and from 92.5-94 are 7 bolt. 6 bolts are better b/c the 7 bolt hasa posible problem called Crankwalk (please do not ask what it is. you can find this easy enough in a search).
Growl
Sep 22, 2012 01:23 AM
toad
Apr 15, 2010 06:40 AM
5Tizzle
Dec 31, 2006 12:56 AM
TCossuto
May 31, 2006 12:27 PM
deltadawn
Jun 15, 2005 06:47 PM
