new car questions
just bought a 98 GS-T spyder with a possiblyjunk motor. i am needing to find if there is and what is thedifference between 4G63T and 4G63. also will a 1st gen. bolt in directly? i don t want to purchase the wrong motor. THANKS
well all the "T" stands for is "Turbo". And there is a list of mods on here somewhere for the 1g swap... lemme see if i can find it
woop, seb beat me to it, we must have posted at the same time... anywho, hear's the link to what you're lookin for https://mitsubishiforum.com/m_155892/tm.htm
like they said T for turbo motor, the non turbos have higher compression pistons of course, just be sure to get a turbo motor unless your gonna rebuild it, then you can get pistons to go with what your doing.
6 bolt swap is easy for the most part, go for it.
whats wrong with the motor in the car?
ORIGINAL: sk8dudety
also not all 1g engines are 6 bolt. the 89-92.5 are 6 bolt and from 92.5-94 are 7 bolt. 6 bolts are better b/c the 7 bolt hasa posible problem called Crankwalk (please do not ask what it is. you can find this easy enough in a search).
deltadawn
Jun 15, 2005 06:47 PM
