Ok, back to my cooling ^^
Old Feb 18, 2008 | 06:58 AM
PappiDread6's Avatar
Default RE: Ok, back to my cooling ^^
Why do you think you need a new set of motor mounts? What you have done to the car so far repair wise?
Old Feb 18, 2008 | 11:58 AM
bagaak's Avatar
i havnt dont anything besides ran a coolant flush, changed the thermostat, and changed the oil, but there a minor vibration witch im not fond of when i let go of the accelerator. i think it would be the mounts being bad. but slowly but steady ill get her running fine ^^
Old Feb 19, 2008 | 07:30 AM
Do you have an Auto or manual. With the mounts being bad the only way I know of checking them is by rockin you engine. Have some1 inside the car with the break on and quickly snap the gas peddle see if you have excessive movement with the upper mounts you can see cracks in the mount material when you do this. The vibration when decelerating I don't know what that is right now I will have to hit a tech at work to get some ideas. But when decelerating where are you rpms? if its and auto does it happen in reverse? with the manual does it happen when still in gear and you let off the gas and/or when you in neutral and let off? Is this a common thing or only happens during certain time of day?
Hendo
Feb 19, 2011 05:40 AM
scitron
Nov 23, 2007 06:03 PM
hara_ca
May 25, 2007 08:09 PM
Silvertooth
Mar 16, 2007 04:42 PM
jdmeclipse92
Oct 29, 2004 12:58 AM
