power lost
Old Jan 24, 2006 | 03:41 PM
NESpeed's Avatar
Default RE: power lost
Does the car idle any different after the intake was installed? But like Emonz said it sounds like a MAS problem, double and triple check that its in right.
Old Jan 24, 2006 | 04:07 PM
get435's Avatar
ORIGINAL: NESpeed
Well first off, dont listen to Get435 about sparying soapy water, thats just idiotic. If you want to check for any vaccum leaks(which it doesnt sound like it is) you take carb cleaner or starter fluid and spray hoses/intake exc. If there is a leak the idle will jump up. Also there is a arrow on the MAS Air that indicates the which way the air flows. SO you want the arrow pointing at the motor. Take some pictures for us and post them so we can get a better look.
Either way it works no problems the only differantc is bubbles are eaier to see than a little wet spot besides the fact a vacume line has two ends who is to say when he installed it it didnt creat a hole on the other sid or in thge middle of it?
Old Jan 24, 2006 | 04:23 PM
NESpeed's Avatar
Wait though are we not talking about vaccum?? HOw are you going to see these bubbles in the hoses? ANYWAYS, it does not sound like a vaccum leak.
Old Jan 24, 2006 | 04:27 PM
I dont think the problem here is a VAC line anyway. you dont need to touch any VAC lines for an intake install other than the one from the valve cover. I think he did something to the MAF when installing it back on. I bet it is something stupid that is the problem
Old Jan 24, 2006 | 04:37 PM
get435's Avatar
ORIGINAL: NESpeed
smaller bubbles will apper around the hole will stiil aper near the hole.
Old Jan 24, 2006 | 09:45 PM
Lil red's Avatar
Maybe the ecu needs to relearn the air intake curve with the new filter. Did you try to reset the ecu?
Old Jan 24, 2006 | 10:58 PM
ORIGINAL: Lil red
I dont think that would happen, but I guess it isnt out of question. I have done tons of intakes and never once had any trouble
mitsnewbie68
Aug 30, 2012 03:07 AM
ralliartguy
Jan 16, 2011 08:04 PM
Envious7
Apr 22, 2010 08:23 PM
Fe2O3
Oct 28, 2009 05:46 PM
ProjectDrknss
Sep 21, 2009 08:29 PM
