Replacing Clutch in a 96 GSX
Old Sep 6, 2007 | 10:57 AM
Wi_Fibre's Avatar
Default RE: Replacing Clutch in a 96 GSX
I'm guessing you already know this, but I'm pretty sure the layout of the GSX is quite different compared to that of the GS, and GST because of it being AWD, so I'm pretty sure that the process will be a little more involved. But I can't say for sure because I really don't know, just using my best judgement call on it. So has anyone here replaced a clutch on a 2g GSX?
Old Sep 6, 2007 | 11:21 AM
Believe it or not... the transmission configuration on teh GST and the GSX is the same. The only difference is the transfer case and driveshaft etc...
Old Sep 6, 2007 | 11:34 AM
Wi_Fibre's Avatar
Oh, ok. Well that's assuring to know, so is the process of replacing the clutch fairly similar for the GST & GSX, or are there a few extra steps needed in some parts?
Old Sep 6, 2007 | 11:36 AM
Yes there are extra steps.. like a little extra unbolting of the AWD components... nothing catastrophic.
Old Sep 6, 2007 | 11:40 AM
99clipsgst's Avatar
I'm looking to upgrade the clutch in my gst. Well what I want to know is How much more does ACT 2100 and ACT 2600 hold over stock. What would work better with the modsI have done. Also How much HP do you think I have?
MODS
8.5:1 pistons, Big T28 60 trim Turbo, Boost 15 PSI, Alamo side mount IC, Greddy metal IC piping and Type RS bov, Ported stock O2 housing, 3" tsuedo cat back, 2.5" downpipe, Injen Intake, 190L fuel pump, ss fuel feed line.
Old Sep 6, 2007 | 01:50 PM
Nice!
If you go to the ACT website it has a graph on there
http://www.advancedclutch.com/produc...d_id=2119#2119Right there. The stock holds about 300ish ft lb before it really starts wearing it down.
If you ask me your next mods should be EVO III 16g, FMIC, and if yo uwant to go further then Denso 660s and SAFC II. Also with the 190lph on there you can boost up a little more. Just keep doin till you hit fuel cut : ) i didnt hit fuel cut until 20 on my moms GST with a 255lph.
Old Sep 6, 2007 | 02:58 PM
ORIGINAL: Sebba
Dont forget about need to remove the drivetrain to be able to drop the tranny
Old Sep 6, 2007 | 02:59 PM
I thought that was obvious? lol
Dhanu
Jun 2, 2014 10:26 AM
wheatbread
May 6, 2010 12:10 AM
FFXLuc
Jul 24, 2006 11:04 AM
brina22maree
Nov 10, 2005 12:05 PM
gsx man
Mar 22, 2005 03:07 AM
