SAFC II
Old Jan 22, 2007 | 09:47 AM
  #41
Default RE: SAFC II
At zero psi boostit should be 37psi
Old Jan 22, 2007 | 10:10 AM
  #42
racerx55's Avatar
Default RE: SAFC II
ok ill try there
Old Jan 22, 2007 | 10:13 AM
  #43
Default RE: SAFC II
BTW i got these #'s from Vfaq. The basic formula that they used was starting from the base at 37psi for a 1g. Then having2 units of vaccuum = 1 psi and every 1psi of boost = 1 psi so like at 5 psi you should be around 42psi fuel pressure. Or if your at 10 vaccuum then you should be around 32psi fuel pressure.
92_laser
1st Generation
Jan 22, 2006 03:15 PM
antlip
Dec 27, 2005 08:44 PM
chrispimpryan86
Dec 8, 2005 12:26 AM
16psi eclipse
Oct 1, 2005 01:51 PM
1320a
Mar 6, 2005 10:00 PM
