SAFC II
BTW i got these #'s from Vfaq. The basic formula that they used was starting from the base at 37psi for a 1g. Then having2 units of vaccuum = 1 psi and every 1psi of boost = 1 psi so like at 5 psi you should be around 42psi fuel pressure. Or if your at 10 vaccuum then you should be around 32psi fuel pressure.
