Shift lag
i used to have the same problem. which brand do you have? when you put it into first is there any play in the **** towards and away from the consol? did you get the upgraded bushings?
no, i have a short "throw" shifter also and had the same problem, if you are in first and as close to nuetral as possible than it's fine but i had a lot of play in mine so i could move it another inch or so forward and would hit my knuckles on the radio. i spent 20bucks on the upgraded bushings from CIMotorsports.net and never had the problem again.
ORIGINAL: RCJr9186
I pulled it off and it was cracked and starting to seperate.
Eclipse440
07-14-2015 11:08 PM
Missile
11-26-2006 10:54 PM
