slave cylinder problems
Old Oct 12, 2006 | 10:54 PM
jerusry's Avatar
Default slave cylinder problems
i was wondering if my slave cylinder going bad and leaking... or a lot of air in clutch lines would make my clutch not release fully and slip?? when i push in the clutch and release it the throwout bearing rod stays in the same position. like the clutch is not releasing... do you get what i am saying? plz help.. thnks!
Old Oct 12, 2006 | 11:39 PM
jerusry's Avatar
Default RE: slave cylinder problems
i should mention that the clutch is brand new... and it worked great until the clutch pedal felt a little sloppy and then the clutch felt squishy and the clutch started slippin really bad... and i am thinking it is cuz the slave cylinder is bad and was leakin and eventually leaked too much... what you guys think?
Old Oct 12, 2006 | 11:47 PM
estraw's Avatar
if the car is in gear and you have the clutch pedal pushed in, does the car stall?
Old Oct 13, 2006 | 12:12 AM
jerusry's Avatar
no it is works fine, just the clutch slips now. and it wasnt gradual... it was like... i pulled into the place parked... went back to it when i got outta the car... got in the car and it took two tries to sart the car so i had the clutch to the floor for a while.. and then when i went to leave the clutch was slipping alot... i had just bled all the lines... but when i checked it on the car... the resevoir was empty... and i think it all leaked out the slave cylinder... but would this cause the clutch to slip? the throwout bearing/ rod dosnt move when i push the clutch...if i am lookin at it from the front it is always to the left...
Old Oct 13, 2006 | 06:35 AM
i would check the lines at the connections to make sure they are on correctly.
Old Oct 13, 2006 | 09:04 AM
jerusry's Avatar
you mean the lines to the slave cylinder? which lines exactly are you talking about?
Old Oct 13, 2006 | 10:07 AM
all the clutch hydraulic lines
Old Oct 15, 2006 | 04:15 AM
Simss's Avatar
did you put the new clutch in your self?
kevinc
Mar 10, 2012 05:02 PM
Natedogg89
Sep 18, 2007 10:07 PM
EveIsle
Sep 13, 2006 10:03 PM
micahman
Mar 3, 2006 10:52 PM
antomx
Feb 3, 2006 10:49 AM
