spyder is very thirsty
Old Jun 21, 2007 | 07:00 PM
ldmiller's Avatar
Default spyder is very thirsty
I purchased a 97 spyder gst last weekend. It has given the dreaded P0170 code. Made sure there is premium fuel in the tank. Still turns the check engine light on in about 25 miles. Also the fuel economy is 17 mpg on the highway. I think thats a little low, isn't it?
Old Jun 21, 2007 | 07:11 PM
Default RE: spyder is very thirsty
P0170 Fuel Trim Malfunction (Bank 1)
Not quite sure what this means.
Dissconnect the battery and put the key in the ignition to drain any excess power. Then wait a couple mins and reconnect it. That should reset the ECU. See if that fixes the problem
Old Jun 21, 2007 | 09:35 PM
Dusty Eclipse's Avatar
It means that its likely running in a lean condition. Id look for a leak post-maf.
Old Jun 21, 2007 | 09:49 PM
Running lean and ****ty gas mileage? You sure?
Old Jun 21, 2007 | 09:54 PM
That should have said lean/rich, sorry about that... wasnt thinking apparently. It could very well be either, in my case specificaly it was lean.
Old Jun 21, 2007 | 10:01 PM
You were getting ****ty MPG with running lean?
Old Jun 21, 2007 | 10:04 PM
No, of course not... I had just gotten that code. It was a leak near the TB.
Lol, think Sebba.
Old Jun 21, 2007 | 10:07 PM
Well thats helpfull.
Im with you. Boost leak
Old Jun 22, 2007 | 09:15 AM
RCJr9186's Avatar
go to home depot and make a boost leak tester... 2 pieces of 2.5" pvc pipe, 1 90degree elbow, cap w/ air hose connector, psi gauge and a coupler to tie it onto ur turbo. then hook up a compressor, pressurize the lines and listen for the pssssssssssss. that easy
armymen
Apr 20, 2012 11:39 AM
blackeclipseGT
Aug 11, 2004 11:37 AM
WGONFAN
Jun 30, 2004 12:02 AM
Ray00
Apr 30, 2004 09:45 AM
gstdave
Dec 10, 2003 09:27 PM
