Is this the starter?
Old Apr 19, 2006 | 08:22 PM
Default RE: Is this the starter?
Its not lol... its right by the drivers side front wheel... just above it i think. Yea im dead serious about the hammer. If it wont turn over its because its stuck... hitting it will solve that lol.... till the next time you need tos tart it obviously lol.... Just give it a good whack on the case and that should free it up.
Old Apr 19, 2006 | 08:36 PM
halloween31r's Avatar
Replacing a starter on that year turbo eclipse is a pain. Your hands get pinched a lot when you are removing and installing the starter. It also takes a great amount of your afternoon. I would definitely sugggest some universal sockets.
Old Apr 19, 2006 | 10:00 PM
An easyer way to do it would be jack it up and remove the wheel..... i think
Old Apr 19, 2006 | 10:27 PM
agallardo's Avatar
Thanks guys for your help.
Old Apr 19, 2006 | 10:30 PM
Mine is in the shop now for a starter replacement lol.
Old Apr 19, 2006 | 10:38 PM
agallardo's Avatar
How long does it usually take for the starter to be installed?
Old Apr 19, 2006 | 10:41 PM
I really wouldnt know. The people in england are dumbasses and it will probly take them like 3-4 hours. Maybe it will be less for you guys in the US beings that Eclipses are a lil more common lol
Old May 2, 2006 | 10:09 PM
99clipsgst's Avatar
Ok I have replace a starter on a 96 RS and it is in the front under the header. for that it takes maybe a half hour. I also replaced the starter on my 99 GST. the location of the starter makes it hadr to hit w/ a hammer bc its under the intake manifold and you need to be under the car to get to it. If you get stuck and you have a manual you can pop the clutch and it will start. just get someone to push the car up to like 10 mPH then pop the cluch and turn the key and give a lil gas. However the install for a 4g63 engine takes around 1.5 hours. just get a ramp and some sockets. remove the battery and the plate the battery sits on then go under the car un bolt the 2 bolts and one nut and it take some time to get it out of the car once it's unbolted.
stealth1
Jul 28, 2005 12:32 AM
Smejk
Feb 11, 2005 07:34 PM
cptkid570
Dec 23, 2004 03:47 AM
Flipz
Dec 12, 2004 04:51 PM
cptkid570
Nov 29, 2004 10:49 AM
